[GRASS-dev] Exporting maps as multilayer GeoTIFF - layer limit?
Markus Neteler neteler at osgeo.org
Sun Nov 24 22:01:19 PST 2013
Nikos,
the file is also generated here but the layers are of value 0.0
starting with layer 145...
I used gdalinfo -mm geotiff to find out. Also using latest SVN version
here, recompiled after distclean.
Best
Markus
On 11/25/13, Nikos Alexandris <nik at nikosalexandris.net> wrote:
> Markus Neteler wrote:
>> I struggle to export a time series as multilayer GeoTIFF: it stops at
>> layer
>> 145.
> Markus, your script works here! The exported file:
> gdalinfo multilayer.tif -nogcp -noct -nomd | tail -5
> Band 361 Block=1x1 Type=Float64, ColorInterp=Undefined
> Band 362 Block=1x1 Type=Float64, ColorInterp=Undefined
> Band 363 Block=1x1 Type=Float64, ColorInterp=Undefined
> Band 364 Block=1x1 Type=Float64, ColorInterp=Undefined
> Band 365 Block=1x1 Type=Float64, ColorInterp=Undefined
> Nikos
