[GRASS-dev] [GRASS GIS] #2033: Moving g.pnmcomp to lib/display to improve render performance of wxGUI
Martin Landa
landa.martin at gmail.com
Tue Nov 26 13:51:05 PST 2013
2013/11/26 Glynn Clements <glynn at gclements.plus.com>:
> The fastest solution is what you get if you use the cairo driver and
> $GRASS_PNGFILE has a ".xid" suffix. The driver creates an X11 or
it's not really related to this issue. Anyway it would be probably
good idea to rename all environmental variables related to rendering,
e.g. GRASS_WIDTH to GRASS_DISPLAY_WIDTH, GRASS_DISP_WIDTH, or
GRASS_RENDER_WIDTH and so on.
The variable GRASS_PNGFILE is also very misleading name, it's not used
only for producing PNG files. Cairo driver supports many formats which
are given by filename extension, so probably GRASS_DISPLAY_FILE would
be better.
What do you think?
Martin
