[GRASS-dev] [GRASS GIS] #2089: i.landsat.toar doesn't take into account the resolution difference between panchromatic and the other bands.
trac at osgeo.org
Fri Oct 4 06:36:53 PDT 2013
Reporter: vesnikos | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.0.0
Component: Imagery | Version: svn-trunk
Keywords: i.landsat.toar | Platform: All
Cpu: Unspecified |
Comment(by neteler):
Replying to [ticket:2089 vesnikos]:
> i.landsat.toar transforms the sensors DN to top of the atmosphere
radiance/reflectance.
> All bands except band 8 (panchromatic) have a pixel size of 30m. Band 8
has pixel size of 15.
Did you check the input resolution? I tested it with the Raleigh scene
LC80160352013134LGN03.tar.gz:
for i in `ls LC*.TIF` ; do echo -n "$i: " ; gdalinfo $i | grep Pixel ;
done
LC80160352013134LGN03_B10.TIF: Pixel Size =
(30.000000000000000,-30.000000000000000)
LC80160352013134LGN03_B11.TIF: Pixel Size =
LC80160352013134LGN03_B1.TIF: Pixel Size =
LC80160352013134LGN03_B2.TIF: Pixel Size =
LC80160352013134LGN03_B3.TIF: Pixel Size =
LC80160352013134LGN03_B4.TIF: Pixel Size =
LC80160352013134LGN03_B5.TIF: Pixel Size =
LC80160352013134LGN03_B6.TIF: Pixel Size =
LC80160352013134LGN03_B7.TIF: Pixel Size =
LC80160352013134LGN03_B8.TIF: Pixel Size =
(15.000000000000000,-15.000000000000000)
LC80160352013134LGN03_B9.TIF: Pixel Size =
LC80160352013134LGN03_BQA.TIF: Pixel Size =
The TIFF files are delivered as such (only B8 is 15m).
I also see that even the PAN B8 band is set to 30m in GRASS 7:
i.landsat.toar input_prefix=LC80160352013134LGN03_B output_prefix=toar \
metfile=LC80160352013134LGN03_MTL.txt sensor=oli8 date=2013-05-14 -r
for i in `g.mlist rast pattern="toar*"` ; do echo "$i: " ; r.info -g $i |
grep -i res ; done
toar1:
nsres=30
ewres=30
toar10:
nsres=30
ewres=30
toar11:
nsres=30
ewres=30
toar2:
nsres=30
ewres=30
toar3:
nsres=30
ewres=30
toar4:
nsres=30
ewres=30
toar5:
nsres=30
ewres=30
toar6:
nsres=30
ewres=30
toar7:
nsres=30
ewres=30
toar8:
nsres=30 <<-- should be 15
ewres=30 <<-- should be 15
toar9:
nsres=30
ewres=30
Using
g.version -g
version=7.0.svn
date=2013
revision=57610
build_date=2013-09-08
NOTE: In GRASS 6 i.landsat.toar preserves the resolution. Must be a bug in
the
usage of Rast_get_cellhd() in the G7 version?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2089#comment:3>
