[GRASS-dev] [GRASS GIS] #2091: r.series error in GRASS7 wxGUI
GRASS GIS trac at osgeo.org
Sun Oct 6 16:38:08 PDT 2013
 Reporter:  richardc         |       Owner:  grass-dev@…
     Type:  defect           |      Status:  new
 Priority:  normal           |   Milestone:  7.0.0
Component:  wxGUI            |     Version:  svn-trunk
 Keywords:  r.series, wxGui  |    Platform:  Linux
      Cpu:  x86-32           |
Comment(by annakrat):
 Should be fixed in r57950. It's connected to #1808 and #1814, so these
 should be fixed now. The problem is that the gui dialog attempts to add
 mapset to the map name if missing. But in case of multiple maps the mapset
 is considered to be everything after the first @ which can be too long and
 then g.findfile crashes. So now it doesn't try to add mapset in case of
 multiple maps. It could add mapset for each of the maps but in case of a
 lot of maps it could slow down everything and I don't really know if
 adding mapsets is needed at all.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2091#comment:5>
