[GRASS-dev] GDAL-GRASS plugin
Pietro
peter.zamb at gmail.com
Tue Oct 8 05:21:17 PDT 2013
Hi all,
I got a strange message, If I try to use gdal from shell (or from
GRASS, using r.in.gdal), I got:
gdalinfo --help
ERROR 1: libgrass_I.so: cannot open shared object file: No such file
or directory
or directory
Usage: gdalinfo [--help-general] [-mm] [-stats] [-hist] [-nogcp] [-nomd]
[-norat] [-noct] [-nofl] [-checksum] [-proj4] [-mdd domain]*
[-sd subdataset] datasetname
I saw:
http://grasswiki.osgeo.org/wiki/Compile_and_install_GDAL-GRASS_plugin
the link to get the GDAL/OGR-GRASS plugin bring to
http://download.osgeo.org/gdal/ where the lastest version is
gdal-grass-1.4.3.tar.gz, but if I look at OSGeo4W, see
http://download.osgeo.org/osgeo4w/release/grass/gdal-grass/
you can see that the last version should be
http://download.osgeo.org/osgeo4w/release/grass/gdal-grass/gdal-grass-1.5.4-4.tar.bz2,
but it seems empty to me...
Which one should I use?
Moreover "A script to configure/install easily can be found here", the link:
http://mpa.itc.it/markus/useful/conf_install_gdal_ogr_grass_plugin.sh
it seems broken.
Trying to compile the gdal-grass:
gdal-grass-1.4.3 $ ./configure --with-grass=$GISBASE
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking for ranlib... ranlib
checking for g++ -shared ... yes
checking for gdal-config... /usr/bin/gdal-config
using /usr/lib/gdalplugins as GDAL shared library autoload directory
checking for G_asprintf in -lgrass_gis... no
configure: error:
--with-grass=/home/pietro/docdat/src/gis/grass/grass_trunk/dist.x86_64-unknown-linux-gnu
requested, but libraries not found! Perhaps you need to set
LD_LIBRARY_PATH to include
/home/pietro/docdat/src/gis/grass/grass_trunk/dist.x86_64-unknown-linux-gnu/lib?
But the LD_LIBRARY_PATH global environment it seems to be set correctly:
gdal-grass-1.4.3 $ echo $LD_LIBRARY_PATH
:/home/pietro/.local/lib:/home/pietro/docdat/src/gis/grass/grass_trunk/dist.x86_64-unknown-linux-gnu/lib
Any ideas how to solve this issue?
Thank you for your help.
Pietro
