[GRASS-dev] [GRASS GIS] #2097: r.modis install using g.extension fails
trac at osgeo.org
Wed Oct 9 07:35:16 PDT 2013
Reporter: pierreroudier | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Addons | Version: svn-trunk
Keywords: MODIS | Platform: Linux
Cpu: x86-64 |
Comment(by madi):
Replying to [comment:3 neteler]:
> Did you try to manually add the missing subdir? Would the installation
work then?
The installation is successfully finished then, BUT the command is not
found, because it is apparently installed in the wrong directory. The
/r.modis folder is placed under /grass-7.0.svn/
Ticket URL: <https://trac.osgeo.org/grass/ticket/2097#comment:4>
