[GRASS-dev] [GRASS GIS] #2097: r.modis install using g.extension fails
GRASS GIS trac at osgeo.org
Wed Oct 9 13:37:34 PDT 2013
 Reporter:  pierreroudier  |       Owner:  grass-dev@…
     Type:  defect         |      Status:  new
 Priority:  normal         |   Milestone:  7.0.0
Component:  Addons         |     Version:  svn-trunk
 Keywords:  MODIS          |    Platform:  Linux
      Cpu:  x86-64         |
Comment(by pierreroudier):
 Replying to [comment:3 neteler]:
 > Did you try to manually add the missing subdir? Would the installation
 work then?
 Same as madi here on Ubuntu:
 GRASS 7.0.svn (eda-rsr):~ > mkdir -p
 /usr/local/grass-7.0.svn/locale/scriptstrings/
 GRASS 7.0.svn (eda-rsr):~ > g.extension ext=r.modisWARNING: Extension
 <r.modis> already installed. Re-installing...
 Fetching <r.modis> from GRASS-Addons SVN (be patient)...
 WARNING: gnome-keyring:: couldn't connect to: /tmp/keyring-VFvFlG/pkcs11:
 No such file or directory
 Compiling...
 Installing...
 Updating metadata file...
 Installation of <r.modis> successfully finished
 GRASS 7.0.svn (eda-rsr):~ > r.modis.import
 ERROR: modis library not found
 It installs but of course the directory is not correct so the library is
 not found.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2097#comment:5>
