[GRASS-dev] [GRASS GIS] #2097: r.modis install using g.extension fails
trac at osgeo.org
Thu Oct 10 09:25:07 PDT 2013
Reporter: pierreroudier | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Addons | Version: svn-trunk
Keywords: MODIS | Platform: Linux
Cpu: x86-64 |
Comment(by wenzeslaus):
`r.modis` is a library (Python packages/modules) and group of modules. Is
somewhere specified how the Makefiles for group of Python modules and
their library should look like? How does the build process deals with this
and how with translations? Is there some official template for the
Makefiles?
* source:grass-addons/grass7/raster/r.modis/Makefile
* source:grass-addons/grass7/raster/r.modis/libmodis/Makefile
* source:grass-addons/grass7/raster/r.modis/r.modis.import/Makefile
* source:grass-addons/grass7/raster/r.modis/r.modis.download/Makefile
It seems that it is implemented in the build system but maybe only
partially? So the current problem is mostly related to the translations?
There is not much about it in SUBMITTING files:
* source:grass-addons/SUBMITTING
* source:grass-addons/SUBMITTING_DOCS
* source:grass-addons/SUBMITTING_PYTHON
* source:grass-addons/SUBMITTING_SCRIPTS
By the way, we probably have a lot of duplication with the SUBMITTING
files in the main source code (trunk and others).
More by the way, there are some invalid links (and probably invalid info
too) in SUBMITTING files:
* http://www-pool.math.tu-berlin.de/~soeren/grass/GRASS_TestSuite (Error:
404 Not Found)
* http://www.grass-gis.org/mailman/listinfo/grass-qa (Errore 404 File non
trovato)
Ticket URL: <https://trac.osgeo.org/grass/ticket/2097#comment:6>
