[GRASS-dev] Handling of Python scripts on MS Windows
Helmut Kudrnovsky hellik at web.de
Wed Oct 9 09:08:29 PDT 2013
> I was referring to cmd.exe *within* a GRASS session.
ok, 2 tests with another windows VISTA box because of travelling (win7-box
from earlier test not available atm), now within a GRASS session:
winGRASS-session (1)
winGRASS 7 standalone installer and no python installation
winGRASS 7 standalone installer bundled with Python 2.7.4 (default, Apr  6
2013, 19:54:46) [MSC v.1500 32 bit (Intel)] on win32
System Info
GRASS version: 7.0.svn
GRASS SVN Revision: 57955
Build Date: 2013-10-08
GIS Library Revision: 56211 (2013-05-12)
GDAL/OGR: 1.9.2
PROJ.4: 4.8.0
GEOS: 3.3.6dev
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-Vista-6.0.6002-SP2
C:\Users\xxxx>assoc .py
Dateizuordnung für die Erweiterung .py nicht gefunden.
File association for the extension. py not found.
C:\Users\xxxx>ftype python.file
Dateityp "python.file" nicht gefunden, oder diesem Dateityp wurde kein
Öffnen-Befehl zugeordnet.
File type "python.file" not found or no associated open command.
C:\Users\xxxx>echo %PATHEXT%
.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC;.PY
winGRASS-session (2)
winGRASS 7 standalone installer and a www.python.org 2.7.5 installation
(system wide installed in C:\Python27)
System Info
GDAL/OGR: 1.9.2
PROJ.4: 4.8.0
GEOS: 3.3.6dev
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
.py=Python.File
python.file="C:\Python27\python.exe" "%1" %*
C:\Users\normal>echo %PATHEXT%
testscript.py:
import sys
print "Hello, World!"
print sys.version
C:\wd\pytest>python testscript.py
Hello, World!
2.7.4 (default, Apr  6 2013, 19:54:46) [MSC v.1500 32 bit (Intel)]
the earlier test was in a win7-box with following python installation
>>python is installed by ArcGIS on this testing box here.
>>ArcGIS 10.0 installed C:\Python26\ArcGIS10.0
>>after upgrade
>>ArcGIS 10.1 installed C:\Python27\ArcGIS10.1
>It suggests that the registry keys are inconsistent.
>ftype and assoc show the system-wide settings, but these are ignored
>if there are per-user keys. If the per-user keys exist but the values
>are invalid, executing a script will result in a dialog asking you to
>select the program to open that type of file.
could it be that ArcGIS installs a "inconsistent" python? if yes how to deal
with this?
AFAIK most of the winGRASS-users has also ArcGIS installed.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Handling-of-Python-scripts-on-MS-Windows-tp5081335p5082670.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
