[GRASS-dev] Handling of Python scripts on MS Windows
Glynn Clements
glynn at gclements.plus.com
Fri Oct 11 11:08:55 PDT 2013
Helmut Kudrnovsky wrote:
> >It suggests that the registry keys are inconsistent.
> >ftype and assoc show the system-wide settings, but these are ignored
> >if there are per-user keys. If the per-user keys exist but the values
> >are invalid, executing a script will result in a dialog asking you to
> >select the program to open that type of file.
> could it be that ArcGIS installs a "inconsistent" python?
Possibly. Run regedit and examine the aforementioned keys.
> if yes how to deal with this?
That would depend upon the details.
If it's a case that's easily detectable and clearly invalid, the
installer can fix it automatically.
Otherwise, it may be possible to have the installer perform a test,
and if it fails direct the user to a "Python on Windows" page on the
GRASS website.
> AFAIK most of the winGRASS-users has also ArcGIS installed.
If it's a specific problem, hopefully it should have a specific
solution.
