[GRASS-dev] [GRASS GIS] #2097: r.modis install using g.extension fails
GRASS GIS trac at osgeo.org
Tue Oct 15 08:28:02 PDT 2013
 Reporter:  pierreroudier  |       Owner:  grass-dev@…
     Type:  defect         |      Status:  new
 Priority:  normal         |   Milestone:  7.0.0
Component:  Addons         |     Version:  svn-trunk
 Keywords:  r.modis        |    Platform:  Linux
      Cpu:  x86-64         |
Comment(by wenzeslaus):
 The unrelated things discussed above have now separate tickets (#2103,
 #2104, #2105) except for ''Missing instruction how to do a multi-module
 addon'' which is probably related to this ticket in the sense that the
 Makefiles are not correct.
 Last fully related comment was done by [comment:5 pierreroudier]:
 > Replying to [comment:3 neteler]:
 > > Did you try to manually add the missing subdir? Would the installation
 work then?
 > Same as madi here on Ubuntu:
 > WARNING: gnome-keyring:: couldn't connect to: /tmp/keyring-
 VFvFlG/pkcs11: No such
 > It installs but of course the directory is not correct so the library is
 not found.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2097#comment:10>
