[GRASS-dev] GRASS70 for Ubuntu in ppa
Johannes Radinger johannesradinger at gmail.com
Wed Oct 9 07:32:20 PDT 2013
On Wed, Sep 4, 2013 at 3:41 PM, Rashad M <rashadkm at gmail.com> wrote:
> gis_set.py was included in grass-gui package. I had seen this issue
> earlier with someone and still didnt fixed it yet. Sorry its a fault on my
> side if its not fixed by adding grass-gui package. If so I will find some
> tim this sunday to fix the problem
Has this issue already been solved? Today, after some time I uninstalled
and reinstalled grass70 (and grass-gui) from the ubuntugis-ppa to check if
it working now. But still I can't launch the GUI with a slightly different
error now. I seems that it is now pointing a least to GRASS70:
Hit RETURN to continue
Starting GRASS GIS...
python: can't open file '/usr/lib/grass70/etc/gui/wxpython/gis_set.py':
[Errno 2] No such file or directory
Received EXIT message from GUI.
I checked an I also couldn't find the folder gui under /usr/lib/grass70/etc/
/Johannes
> On Wed, Sep 4, 2013 at 3:25 PM, Johannes Radinger <
> johannesradinger at gmail.com> wrote:
>> No problem...as I said I just rolled back to precise. So no worry about
>> raring for the moment. On precise I am able to install grass70 from
>> grass-devel ppa and grass643 from ubuntugis-unstable...
>> However when I try to launch both from the console (freshly installed
>> precise) via grass64 or grass70 I get an error:
>> python: can't open file '/usr/lib/grass64/etc/wxpython/gis_set.py':
>> resp.
>> python: can't open file '/usr/lib/grass70/etc/wxpython/gis_set.py':
>> Any idea about that?
>> /Johannes
>> On Wed, Sep 4, 2013 at 2:28 PM, Rashad M <rashadkm at gmail.com> wrote:
>>> there was some problem on raring and I couldn't get time to work on it.
>>> Anyway I will add it to my calender again and let see if I can figure it
>>> out. The main problem is I dont have a raring currently I need to login to
>>> a remote system at my university and do it. I will try this weekend and let
>>> you know
>>> On Wed, Sep 4, 2013 at 2:25 PM, Johannes Radinger <
>>>> At the moment I also saw that the last build failed for raring...
>>>> so for the moment I'll reinstall precise to test grass70
>>>> On Wed, Sep 4, 2013 at 2:18 PM, Rashad M <rashadkm at gmail.com> wrote:
>>>>> Hi,
>>>>> the recipe was not building for raring but I enabled it and you can
>>>>> check back in a while
>>>>> On Wed, Sep 4, 2013 at 1:42 PM, Johannes Radinger <
>>>>>> that one is installed...thats why I am wondering.
>>>>>> I am running Xubuntu (latest actually todays version). The repo
>>>>>> is also listed (e.g. in Synaptic and I see the grass-add ons but
>>>>>> not the grass70)
>>>>>> Maybe because of my new Xubuntu version (Raring ringtail)?
>>>>>> On Wed, Sep 4, 2013 at 1:29 PM, Rashad M <rashadkm at gmail.com> wrote:
>>>>>>> sudo add-apt-repository ppa:grass/grass-devel
>>>>>>> you may need to install add-apt-repository using apt-get install
>>>>>>> On Wed, Sep 4, 2013 at 12:15 PM, Johannes Radinger <
>>>>>>>> Hi Rashad,
>>>>>>>> I just need your little help:
>>>>>>>> I added the grass-devel PPA to my repository and ran sudo apt-get
>>>>>>>> update
>>>>>>>> however there is no grass70 listed which I can install via apt-get
>>>>>>>> install gra*
>>>>>>>> There is a grass and grass-devel listed which seems to be related
>>>>>>>> to the grass 6.4.2
>>>>>>>> (is in the official ubuntu repo?)
>>>>>>>> On Wed, Sep 4, 2013 at 11:51 AM, Rashad M <rashadkm at gmail.com>wrote:
>>>>>>>>> Yes you are right. grass64 is uploaded in UbuntuGIS-unstable PPA
>>>>>>>>> when there is new release including RC's. GRASS PPA has daily builds for
>>>>>>>>> grass64, grass70 and grass-addons. I am sorry its not updated in grass
>>>>>>>>> webpage. I will ask Markus Netler who has can update this page [1]
>>>>>>>>> [1]  http://grass.osgeo.org/download/software/linux/
>>>>>>>>> On Wed, Sep 4, 2013 at 11:48 AM, Johannes Radinger <
>>>>>>>>>> Thank you for the quick reply...
>>>>>>>>>> so just to be sure:
>>>>>>>>>> the grass70 is now located at GRASS GIS PPA.
>>>>>>>>>> the actual stable grass64 (643) is still located in
>>>>>>>>>> or also maintained for GRASS GIS PPA?
>>>>>>>>>> /Johannes
>>>>>>>>>> On Wed, Sep 4, 2013 at 11:28 AM, Rashad M <rashadkm at gmail.com>wrote:
>>>>>>>>>>> you can check grass PPA in ubuntu. I am not adding grass70 to
>>>>>>>>>>> ubuntugis-testing PPA because its getting deleted a lot of time. GRASS GIS
>>>>>>>>>>> PPA has daily builds for grass70 for raring and quantal. You can see
>>>>>>>>>>> details here - https://launchpad.net/~grass/+archive/grass-devel
>>>>>>>>>>> On Wed, Sep 4, 2013 at 11:15 AM, Johannes Radinger <
>>>>>>>>>>>> Hi all,
>>>>>>>>>>>> Hi Rashad,
>>>>>>>>>>>> I just checked the link that is provided here:
>>>>>>>>>>>> which points to the ubuntugis-testing repository
>>>>>>>>>>>> for downloading a precompiled GRASS70 package.
>>>>>>>>>>>> However, this repo does not include GRASS70.
>>>>>>>>>>>> Is there any way resp. any repo that contains already
>>>>>>>>>>>> an actual version of GRASS70 for Ubuntu or do
>>>>>>>>>>>> I have to compile it myself?
>>>>>>>>>>>> Usually I compile it myself but now I just set up a
>>>>>>>>>>>> very slim Xubuntu on a virtual machine for a collegue
>>>>>>>>>>>> and wanted just to simply install GRASS70. Any pointer?
>>>>>>>>>>> Regards,
>>>>>>>>>>>     Rashad
>>>>>>>>> Regards,
>>>>>>>>>     Rashad
>>>>>>> Regards,
>>>>>>>     Rashad
>>>>> Regards,
>>>>>     Rashad
>>> Regards,
>>>     Rashad
> Regards,
>     Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131009/9e10c2cb/attachment-0001.html>
