[GRASS-dev] [GRASS GIS] #2110: error registering maps outside mapset
trac at osgeo.org
Wed Oct 16 07:17:59 PDT 2013
Reporter: lucadelu | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Temporal | Version: svn-trunk
Keywords: register | Platform: All
Cpu: All |
Comment(by huhabla):
The current behavior is a design decision. Space time datasets accept only
maps from the same mapset for registration. A new space time datasets will
be dedicated to the current mapset. The current mapset is part of its
temporal database identifier. Hence space time datasets from different
mapsets can be stored in the same temporal database. This assures that
mapsets can share the same temporal database.
Space time datasets are new datatypes in GRASS and should behave like
raster or vector maps. Hence these datatypes are mapsets specific. It is
possible to access space time datasets from different mapsets for reading,
if the mapsets share the same temporal database. But it should not be
possible to modify space time datasets from different mapsets.
As default the temporal database will be created in the PERMANENT
directory, so that space time datasets and maps from different mapsets can
be registered there. This allows the read only access to the datasets from
different mapsets in the temporal database. To avoid this, the temporal
database can be set mapset specific. Hence each mapset sees only their
space time datasets and registered maps.
This decision was made to reduce confusion, to avoid unexpected behavior
and to assure a convenient behavior of the temporal framework in the GRASS
way.
Examples to support this decision:
If you register maps from a foreign mapset in a space time raster dataset
and you remove the maps in the foreign mapset, then the temporal database
might not be aware of these changes, pointing to maps that have not been
unregistered. In all following operations the effected space time datasets
will produce errors.
If you use "t.remove" with the "-rf" option, the provided space time
datasets and its registered maps will be removed from the temporal and
spatial database (g.remove will be called). This operation will fail if
the registered maps are from different mapsets.
Attention when several mapsets share the same temporal database:
It is still a work in progress to grant only access to space time datasets
and raster maps in the temporal database, that the user has permission to
read --> configured using the GRASS mapset permission system. Hence you
might see space time datasets in the output of "t.list" from different
mapsets, to which you have no permission to access.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2110#comment:1>
