[GRASS-dev] [GRASS GIS] #2110: error registering maps outside mapset
trac at osgeo.org
Wed Oct 16 07:54:15 PDT 2013
Reporter: lucadelu | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Temporal | Version: svn-trunk
Keywords: register | Platform: All
Cpu: All |
Comment(by annakrat):
I ran into problems when I tried to register maps from different mapsets:
although t.register reported that it couldn't register the maps into the
dataset (which is ok according to the desicion), it seemed to register
them into the database. Because then, I switched to that mapset and tried
to register the maps again with a new dataset but it failed because the
maps were already registered (--o helped). I guess the maps should not
have been registered at all?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2110#comment:2>
