[GRASS-dev] [GRASS GIS] #2110: error registering maps outside mapset
trac at osgeo.org
Wed Oct 16 16:35:30 PDT 2013
Reporter: lucadelu | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Temporal | Version: svn-trunk
Keywords: register | Platform: All
Cpu: All |
Comment(by huhabla):
Replying to [comment:2 annakrat]:
> I ran into problems when I tried to register maps from different
mapsets: although t.register reported that it couldn't register the maps
into the dataset (which is ok according to the desicion), it seemed to
register them into the database. Because then, I switched to that mapset
and tried to register the maps again with a new dataset but it failed
because the maps were already registered (--o helped). I guess the maps
should not have been registered at all?
That is correct, this check was not implemented.
I have hopefully solved this issue with commit r58020. Many thanks for the
feedback.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2110#comment:3>
