[GRASS-dev] [GRASS GIS] #2110: error registering maps outside mapset
GRASS GIS trac at osgeo.org
Thu Oct 17 02:02:52 PDT 2013
 Reporter:  lucadelu  |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  normal    |   Milestone:  7.0.0
Component:  Temporal  |     Version:  svn-trunk
 Keywords:  register  |    Platform:  All
      Cpu:  All       |
Comment(by lucadelu):
 Replying to [comment:1 huhabla]:
 > The current behavior is a design decision. Space time datasets accept
 only maps from the same mapset for registration. A new space time datasets
 will be dedicated to the current mapset. The current mapset is part of its
 temporal database identifier. Hence space time datasets from different
 mapsets can be stored in the same temporal database. This assures that
 mapsets can share the same temporal database.
 > Space time datasets are new datatypes in GRASS and should behave like
 raster or vector maps. Hence these datatypes are mapsets specific. It is
 possible to access space time datasets from different mapsets for reading,
 if the mapsets share the same temporal database. But it should not be
 possible to modify space time datasets from different mapsets.
 > As default the temporal database will be created in the PERMANENT
 directory, so that space time datasets and maps from different mapsets can
 be registered there. This allows the read only access to the datasets from
 different mapsets in the temporal database. To avoid this, the temporal
 database can be set mapset specific. Hence each mapset sees only their
 space time datasets and registered maps.
 I'm not sure that this is the right way to follow because PERMANENT may be
 owned by a user differing from the user that is going to create a new
 temporal database in the location (think multi-user location!) so there
 should arise a write permission problem.
 For example, in the location where our group members store MODIS LST data,
 when the user MarkusN previously connected his data to the temporal
 framework, but myself I also connect to it later (here MarkusN's data are
 hence in PERMANENT) I can do that. But when I try to actually create a new
 temporal dataset I obtain this error:
 t.connect -d
 Default driver / database set to:
 driver: sqlite
 database: /grassdata/eu_laea/PERMANENT/tgis/sqlite.db
 t.create out=lst_2003 title=lst_2003 description="LST 2003 dataset"
 ERROR: Unable to execute transaction:
        INSERT INTO strds_base ( name ,creator ,mapset ,creation_time
        ,temporal_type ,id ,semantic_type ) VALUES ('lst_2003' ,'lucadelu'
        ,'lucadelu_test_temporal' ,'2013-10-17 10:33:20.660192' ,'absolute'
        ,'lst_2003 at lucadelu_test_temporal' ,'mean') ;
        INSERT INTO strds_absolute_time ( start_time ,end_time ,granularity
        ,timezone ,id ,map_time ) VALUES (NULL ,NULL ,NULL ,NULL
        ,'lst_2003 at lucadelu_test_temporal' ,NULL) ;
        INSERT INTO strds_spatial_extent ( north ,bottom ,west ,top ,proj
        ,east ,id ,south ) VALUES (NULL ,NULL ,NULL ,NULL ,'XY' ,NULL
        INSERT INTO strds_metadata ( max_min ,description ,ewres_min ,title
        ,min_max ,nsres_min ,nsres_max ,number_of_maps ,raster_register
        ,command ,min_min ,ewres_max ,id ,max_max ) VALUES (NULL ,'LST 2003
        dataset' ,NULL ,'lst_2003' ,NULL ,NULL ,NULL ,NULL ,NULL ,'#
        2013-10-17 10:33:20
        t.create out="lst_2003" title="lst_2003"
        ' ,NULL ,NULL ,'lst_2003 at lucadelu_test_temporal' ,NULL) ;
   File "/home/lucadelu/compilati/grass7/dist.x86_64-unknown-linux-
 gnu/scripts/t.create", line 83, in <module>
     main()
 gnu/scripts/t.create", line 79, in main
     semantic, None, grass.overwrite())
 gnu/etc/python/grass/temporal/open.py", line 169, in
 open_new_space_time_dataset
     sp.insert(dbif)
 gnu/etc/python/grass/temporal/abstract_dataset.py", line 395, in insert
     dbif.execute_transaction(statement)
 gnu/etc/python/grass/temporal/core.py", line 628, in execute_transaction
     self.cursor.executescript(statement)
 sqlite3.OperationalError: attempt to write a readonly database
 It is naturally "read-only" because PERMANENT is owned by MarkusN and not
 by me.[[BR]]
 Another example: I try to create a new temporal DB in another location
 which yet does not contain any temporal DB, but the owner of PERMANENT is
 again MarkusN, I get this error:
 t.connect -d
 driver: sqlite
 database: /grassdata/patUTM32/PERMANENT/tgis/sqlite.db
 Create temporal database: /grassdata/patUTM32/PERMANENT/tgis/sqlite.db
     main()
 gnu/scripts/t.create", line 76, in main
     tgis.init()
 gnu/etc/python/grass/temporal/core.py", line 298, in init
     create_temporal_database(dbif, database)
 gnu/etc/python/grass/temporal/core.py", line 371, in
     os.makedirs(tgis_dir)
   File "/usr/lib/python2.7/os.py", line 157, in makedirs
     mkdir(name, mode)
 OSError: [Errno 13] Permission denied:
 '/grassdata/patUTM32/PERMANENT/tgis'
 So, t.create fails because I cannot write there due to the permission
 management, say, PERMANENT is not and should not be group writable.
 > This decision was made to reduce confusion, to avoid unexpected behavior
 and to assure a convenient behavior of the temporal framework in the GRASS
 way.
 It is unexpected behaviour since it is contrary to the long-term known
 GRASS permission management.
 > Examples to support this decision:
 > If you register maps from a foreign mapset in a space time raster
 dataset and you remove the maps in the foreign mapset, then the temporal
 database might not be aware of these changes, pointing to maps that have
 not been unregistered. In all following operations the effected space time
 datasets will produce errors.
 The same would apply to imagery groups, but this implementation is there
 for many years without real problems. Similar also for r.external and
 r.reclass.area. It is unavoidable that a user takes care of the data
 management. This should not limit the overall usability, hence more
 flexibility is better.
 > If you use "t.remove" with the "-rf" option, the provided space time
 datasets and its registered maps will be removed from the temporal and
 spatial database (g.remove will be called). This operation will fail if
 the registered maps are from different mapsets.
 I understand to some extent your design decision but I see here a big
 problem for people with a shared data storage infrastructure like in our
 group (FEM PGIS).
 For example, MarkusM is reconstructing MODIS LST data and he is at this
 point the owner of the mapset in which the results are stored. This
 mapset's size is of several TB and I have to work with the entire dataset
 (time series). We cannot change the owner of that mapset because it is
 continuously updated through an automated procedure.
 Until now we cannot use temporal framework in our Unit, for my point of
 view this is really a limitation. Please consider to add the possibility
 to work with maps outside the working mapset and I'll be able to continue
 to test the temporal framework.
 Thanks
 Luca
Ticket URL: <http://trac.osgeo.org/grass/ticket/2110#comment:4>
