[GRASS-dev] G7: parameter standardization: n/count, min/minimum etc
Vaclav Petras
wenzeslaus at gmail.com
Wed Oct 16 12:32:22 PDT 2013
I have no suggestion but I just experienced problem with options.
I have options:
* elevation
* end_water_level
So, when I write
elev=... end_wl=...
I get
Sorry, <elev=> is ambiguous
Because I could write also
eleva=... eleve=...
which I'm really not going to do.
It is expected behavior but not exactly what I want. But let's say that it
is just disadvantage because writing
end_wl=
instead of
end_water_level= or end_w_l
is nice.
On Wed, Oct 16, 2013 at 1:40 PM, Glynn Clements <glynn at gclements.plus.com>wrote:
> Markus Neteler wrote:
> > >> I'll look into using > the option-matching code for option values as
> > >> well as names.
> > > Done in r57999.
> > Is there any usage example?
> Rather than just allowing the entire option to be abbreviated to a
> prefix, each word can be abbreviated individually, so e.g.
> minimum_raster could be abbreviated to e.g. minr.
> There remains the issue that if one option is a prefix of another, the
> shorter option must always be given in full, as any abbreviation of it
> will also be a valid abbreviation of the longer option, and thus
> ambiguous.
> Suggestions welcome.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131016/c9186422/attachment.html>
