[GRASS-dev] G7: parameter standardization: n/count, min/minimum etc
Thu Oct 17 14:24:47 PDT 2013
Vaclav Petras wrote:
> I have no suggestion but I just experienced problem with options.
> I have options:
> * elevation
> * end_water_level
> So, when I write
>  elev=... end_wl=...
> I get
>  Sorry, <elev=> is ambiguous
Can you try r58034?
This should ignore ambiguities if the given option is a prefix of
exactly one recognised option.
We might need something similar for option names.
