[GRASS-dev] G7: parameter standardization: n/count, min/minimum etc
Vaclav Petras wenzeslaus at gmail.com
Thu Oct 17 16:04:36 PDT 2013
On Thu, Oct 17, 2013 at 5:24 PM, Glynn Clements <glynn at gclements.plus.com>wrote:
> Vaclav Petras wrote:
> > I have no suggestion but I just experienced problem with options.
> > I have options:
> > * elevation
> > * end_water_level
> > So, when I write
> >  elev=... end_wl=...
> > I get
> >  Sorry, <elev=> is ambiguous
> Can you try r58034?
> This should ignore ambiguities if the given option is a prefix of
> exactly one recognised option.
It reports still the same (I did the distclean to be sure). I wrote a small
script to test it (attached). I'm just not sure how to effectively run it
(without copying it into my dist.../scripts) and we should probably
integrated it into the library (library's test code).
Thanks,
Vaclav
We might need something similar for option names.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131017/27159be9/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131017/27159be9/attachment.obj>
