[GRASS-dev] G7: parameter standardization: n/count, min/minimum etc
Glynn Clements
glynn at gclements.plus.com
Fri Oct 18 08:15:50 PDT 2013
Vaclav Petras wrote:
> > > I have options:
> > > * elevation
> > > * end_water_level
> > > So, when I write
> > > elev=... end_wl=...
> > > I get
> > > Sorry, <elev=> is ambiguous
> > Can you try r58034?
> > This should ignore ambiguities if the given option is a prefix of
> > exactly one recognised option.
> It reports still the same (I did the distclean to be sure).
Sorry; I wasn't paying sufficient attention.
The recent changes only affected option values, where an option
(command-line parameter) has a fixed set of values (e.g. "method="
options). The ability to abbreviate option names has existed for some
time.
r58046 makes a similar change for option names.
