[GRASS-dev] Programming manual updated: gislib
Vaclav Petras wenzeslaus at gmail.com
Fri Oct 18 11:03:34 PDT 2013
I've added even more updates. Now the things from gis.h such as Option
structure or STD_OPT enum are displayed in doxygen docs with member
descriptions. I wrote something but mostly it was just adding doxygen
enabled comments and adding links on places which cannot be recognized by
doxygen.
I was afraid that I will break some special parsing somewhere so I didn't
removed /**/ comment at the beginning of enums. My GRASS compiles and runs,
so probably it is ok.
Additionally, I tried to disable as much test code as possible, so the
documentation should be cleaner now. Remaining things are usually Python
classes or functions because I was disabling using file pattern. There is
also a pattern for entities, maybe we can introduce some naming
convention...
There is also a file ./lib/bitmap/main.c which goes to the docs and I don't
know what's its purpose.
I also excluded *local_proto.h files which were in the docs sometimes.
Vaclav
r58047: https://trac.osgeo.org/grass/changeset/58048
r58048: https://trac.osgeo.org/grass/changeset/58047
On Fri, Oct 18, 2013 at 1:05 AM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> Hi all,
> I've updated the programming manual (r58037), namely Command line parsing
> documentation in gislib.
> I added some important things which were missing such as standard options.
> I changed some wording such as 'parser routines' which really scares me. I
> also changed the description of API in the way that it is object oriented
> as opposed to listing functions and structures separately.
> I encourage every body to contribute to programming manual because it is
> crucial for attracting new developers. Well documented API can be more
> important than the quality of API itself.
>  Best,
> Vaclav
> == Details ==
> The next step could be to move some details from API description to
> particular functions  and structures and leave in the dox files only the
> main things combined with examples.
> I haven't touched the Complete Structure Members Table and Description of
> Complex Structure Members sections which requires another round of
> consideration.
> Feel free to continue in my effort, correct English grammar or improve the
> documentation itself, e.g. with more current example.
> You can compile the programming manual using
>  make htmldox
> and than you can open a file
>  html/index.html
> MarkusN, please, update the online version.
> == Links ==
> The old link is:
> http://grass.osgeo.org/programming7/gislib.html#Command_Line_Parsing
> New links:
> http://grass.osgeo.org/programming7/gislib_cmdline_parsing.html
> Related source codes:
> http://grass.osgeo.org/programming7/parser__standard__options_8c_source.html
> http://grass.osgeo.org/programming7/parser__standard__options_8c.html
> http://grass.osgeo.org/programming7/gis_8h.html
> Change sets:
> https://trac.osgeo.org/grass/changeset/58036 (mv)
> https://trac.osgeo.org/grass/changeset/58037 (chnages)
> Related GRASS Wiki pages:
> http://grasswiki.osgeo.org/wiki/Module_command_line_parser
> http://grasswiki.osgeo.org/wiki/GRASS_Programming_Howto
> http://grasswiki.osgeo.org/wiki/GRASS_Python_Scripting_Library
> (some of them are trying to substitute programming manual)
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131018/d73d90ef/attachment.html>
