[GRASS-dev] ccmath compilation error
Yann Chemin ychemin at gmail.com
Sun Oct 20 07:47:00 PDT 2013
Yes Markus, seems to be an Ubuntu 13.04 issue with both my nettop (Atom)
pcs.
I am upgrading this one too in the hope to fix the same way.
On 20 October 2013 17:26, Markus Neteler <neteler at osgeo.org> wrote:
> On Sun, Oct 20, 2013 at 9:48 AM, Yann Chemin <ychemin at gmail.com> wrote:
> > lib/external/ccmath$ make
> > make lib
> > make[1]: Entering directory
> > `/home/yann/grass_dev/grass_yann/lib/external/ccmath'
> > gcc  -g -O2  -fPIC
> > -I/home/yann/grass_dev/grass_yann/dist.i686-pc-linux-gnu/include
> > -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64  -DPACKAGE=\""grasslibs"\"
> > -I/home/yann/grass_dev/grass_yann/dist.i686-pc-linux-gnu/include -o
> > OBJ.i686-pc-linux-gnu/house.o -c house.c
> > house.c: In function ‘house’:
> > house.c:10:6: internal compiler error: in rewrite_use_nonlinear_expr, at
> > tree-ssa-loop-ivopts.c:6215
> > Please submit a full bug report,
> > with preprocessed source if appropriate.
> > See <file:///usr/share/doc/gcc-4.7/README.Bugs> for instructions.
> > Preprocessed source stored into /tmp/cc8wc4KR.out file, please attach
> this
> > to your bugreport.
> > make[1]: *** [OBJ.i686-pc-linux-gnu/house.o] Error 1
> > make[1]: Leaving directory
> > make: *** [default] Error 2
> > GCC version
> > gcc -v
> > Using built-in specs.
> > COLLECT_GCC=gcc
> > COLLECT_LTO_WRAPPER=/usr/lib/gcc/i686-linux-gnu/4.7/lto-wrapper
> > Target: i686-linux-gnu
> > Configured with: ../src/configure -v --with-pkgversion='Ubuntu/Linaro
> > 4.7.3-1ubuntu1' --with-bugurl=file:///usr/share/doc/gcc-4.7/README.Bugs
> > --enable-languages=c,c++,go,fortran,objc,obj-c++ --prefix=/usr
> > --program-suffix=-4.7 --enable-shared --enable-linker-build-id
> > --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix
> > --with-gxx-include-dir=/usr/include/c++/4.7 --libdir=/usr/lib
> --enable-nls
> > --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug
> > --enable-libstdcxx-time=yes --enable-gnu-unique-object --enable-plugin
> > --with-system-zlib --enable-objc-gc --enable-targets=all --with-cloog
> > --enable-cloog-backend=ppl --disable-cloog-version-check
> > --disable-ppl-version-check --enable-multiarch --disable-werror
> > --with-arch-32=i686 --with-multilib-list=m32,m64,mx32 --with-tune=generic
> > --enable-checking=release --build=i686-linux-gnu --host=i686-linux-gnu
> > --target=i686-linux-gnu
> > Thread model: posix
> > gcc version 4.7.3 (Ubuntu/Linaro 4.7.3-1ubuntu1)
> You posted that also earlier this year with this solution:
> http://lists.osgeo.org/pipermail/grass-dev/2013-June/064468.html
> "I have not had that problem after upgrading the machine..."
> Perhaps try that again on your actual system?
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131020/fe538dba/attachment.html>
