[GRASS-dev] ccmath compilation error
Rashad M mohammedrashadkm at gmail.com
Mon Oct 21 14:08:41 PDT 2013
This is only for ubuntu 13.04 34bit. Failing for a long time in launchpad
builds[1]. I had filed a bug report[2] but no response yet.
[1]
https://launchpadlibrarian.net/149593351/buildlog_ubuntu-raring-i386.grass70_7.0.0%2B0ubuntu2%2B29074~ubuntu13.04.1_FAILEDTOBUILD.txt.gz
[2] https://bugs.launchpad.net/ubuntu/+source/gcc-4.7/+bug/1201048
Unfortunately no response. Too bad for a gcc project.
On Sun, Oct 20, 2013 at 4:47 PM, Yann Chemin <ychemin at gmail.com> wrote:
> Yes Markus, seems to be an Ubuntu 13.04 issue with both my nettop (Atom)
> pcs.
> I am upgrading this one too in the hope to fix the same way.
> On 20 October 2013 17:26, Markus Neteler <neteler at osgeo.org> wrote:
>> On Sun, Oct 20, 2013 at 9:48 AM, Yann Chemin <ychemin at gmail.com> wrote:
>> > lib/external/ccmath$ make
>> > make lib
>> > make[1]: Entering directory
>> > `/home/yann/grass_dev/grass_yann/lib/external/ccmath'
>> > gcc  -g -O2  -fPIC
>> > -I/home/yann/grass_dev/grass_yann/dist.i686-pc-linux-gnu/include
>> > -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64  -DPACKAGE=\""grasslibs"\"
>> > -I/home/yann/grass_dev/grass_yann/dist.i686-pc-linux-gnu/include -o
>> > OBJ.i686-pc-linux-gnu/house.o -c house.c
>> > house.c: In function ‘house’:
>> > house.c:10:6: internal compiler error: in rewrite_use_nonlinear_expr, at
>> > tree-ssa-loop-ivopts.c:6215
>> > Please submit a full bug report,
>> > with preprocessed source if appropriate.
>> > See <file:///usr/share/doc/gcc-4.7/README.Bugs> for instructions.
>> > Preprocessed source stored into /tmp/cc8wc4KR.out file, please attach
>> this
>> > to your bugreport.
>> > make[1]: *** [OBJ.i686-pc-linux-gnu/house.o] Error 1
>> > make[1]: Leaving directory
>> > make: *** [default] Error 2
>> > GCC version
>> > gcc -v
>> > Using built-in specs.
>> > COLLECT_GCC=gcc
>> > COLLECT_LTO_WRAPPER=/usr/lib/gcc/i686-linux-gnu/4.7/lto-wrapper
>> > Target: i686-linux-gnu
>> > Configured with: ../src/configure -v --with-pkgversion='Ubuntu/Linaro
>> > 4.7.3-1ubuntu1' --with-bugurl=file:///usr/share/doc/gcc-4.7/README.Bugs
>> > --enable-languages=c,c++,go,fortran,objc,obj-c++ --prefix=/usr
>> > --program-suffix=-4.7 --enable-shared --enable-linker-build-id
>> > --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix
>> > --with-gxx-include-dir=/usr/include/c++/4.7 --libdir=/usr/lib
>> --enable-nls
>> > --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug
>> > --enable-libstdcxx-time=yes --enable-gnu-unique-object --enable-plugin
>> > --with-system-zlib --enable-objc-gc --enable-targets=all --with-cloog
>> > --enable-cloog-backend=ppl --disable-cloog-version-check
>> > --disable-ppl-version-check --enable-multiarch --disable-werror
>> > --with-arch-32=i686 --with-multilib-list=m32,m64,mx32
>> --with-tune=generic
>> > --enable-checking=release --build=i686-linux-gnu --host=i686-linux-gnu
>> > --target=i686-linux-gnu
>> > Thread model: posix
>> > gcc version 4.7.3 (Ubuntu/Linaro 4.7.3-1ubuntu1)
>> You posted that also earlier this year with this solution:
>> http://lists.osgeo.org/pipermail/grass-dev/2013-June/064468.html
>> "I have not had that problem after upgrading the machine..."
>> Perhaps try that again on your actual system?
>> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Regards,
   Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131021/4887c6f3/attachment.html>
