[GRASS-dev] ccmath compilation error
Yann Chemin ychemin at gmail.com
Mon Oct 21 19:39:07 PDT 2013
Yes an upgrade to 13.10 does (again) solve the problem
On 22 October 2013 02:38, Rashad M <mohammedrashadkm at gmail.com> wrote:
> This is only for ubuntu 13.04 34bit. Failing for a long time in launchpad
> builds[1]. I had filed a bug report[2] but no response yet.
> [1]
> https://launchpadlibrarian.net/149593351/buildlog_ubuntu-raring-i386.grass70_7.0.0%2B0ubuntu2%2B29074~ubuntu13.04.1_FAILEDTOBUILD.txt.gz
> [2] https://bugs.launchpad.net/ubuntu/+source/gcc-4.7/+bug/1201048
> Unfortunately no response. Too bad for a gcc project.
> On Sun, Oct 20, 2013 at 4:47 PM, Yann Chemin <ychemin at gmail.com> wrote:
>> Yes Markus, seems to be an Ubuntu 13.04 issue with both my nettop (Atom)
>> pcs.
>> I am upgrading this one too in the hope to fix the same way.
>> On 20 October 2013 17:26, Markus Neteler <neteler at osgeo.org> wrote:
>>> On Sun, Oct 20, 2013 at 9:48 AM, Yann Chemin <ychemin at gmail.com> wrote:
>>> > lib/external/ccmath$ make
>>> > make lib
>>> > make[1]: Entering directory
>>> > `/home/yann/grass_dev/grass_yann/lib/external/ccmath'
>>> > gcc  -g -O2  -fPIC
>>> > -I/home/yann/grass_dev/grass_yann/dist.i686-pc-linux-gnu/include
>>> > -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64  -DPACKAGE=\""grasslibs"\"
>>> > -I/home/yann/grass_dev/grass_yann/dist.i686-pc-linux-gnu/include -o
>>> > OBJ.i686-pc-linux-gnu/house.o -c house.c
>>> > house.c: In function ‘house’:
>>> > house.c:10:6: internal compiler error: in rewrite_use_nonlinear_expr,
>>> at
>>> > tree-ssa-loop-ivopts.c:6215
>>> > Please submit a full bug report,
>>> > with preprocessed source if appropriate.
>>> > See <file:///usr/share/doc/gcc-4.7/README.Bugs> for instructions.
>>> > Preprocessed source stored into /tmp/cc8wc4KR.out file, please attach
>>> this
>>> > to your bugreport.
>>> > make[1]: *** [OBJ.i686-pc-linux-gnu/house.o] Error 1
>>> > make[1]: Leaving directory
>>> > make: *** [default] Error 2
>>> > GCC version
>>> > gcc -v
>>> > Using built-in specs.
>>> > COLLECT_GCC=gcc
>>> > COLLECT_LTO_WRAPPER=/usr/lib/gcc/i686-linux-gnu/4.7/lto-wrapper
>>> > Target: i686-linux-gnu
>>> > Configured with: ../src/configure -v --with-pkgversion='Ubuntu/Linaro
>>> > 4.7.3-1ubuntu1' --with-bugurl=file:///usr/share/doc/gcc-4.7/README.Bugs
>>> > --enable-languages=c,c++,go,fortran,objc,obj-c++ --prefix=/usr
>>> > --program-suffix=-4.7 --enable-shared --enable-linker-build-id
>>> > --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix
>>> > --with-gxx-include-dir=/usr/include/c++/4.7 --libdir=/usr/lib
>>> --enable-nls
>>> > --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug
>>> > --enable-libstdcxx-time=yes --enable-gnu-unique-object --enable-plugin
>>> > --with-system-zlib --enable-objc-gc --enable-targets=all --with-cloog
>>> > --enable-cloog-backend=ppl --disable-cloog-version-check
>>> > --disable-ppl-version-check --enable-multiarch --disable-werror
>>> > --with-arch-32=i686 --with-multilib-list=m32,m64,mx32
>>> --with-tune=generic
>>> > --enable-checking=release --build=i686-linux-gnu --host=i686-linux-gnu
>>> > --target=i686-linux-gnu
>>> > Thread model: posix
>>> > gcc version 4.7.3 (Ubuntu/Linaro 4.7.3-1ubuntu1)
>>> You posted that also earlier this year with this solution:
>>> http://lists.osgeo.org/pipermail/grass-dev/2013-June/064468.html
>>> "I have not had that problem after upgrading the machine..."
>>> Perhaps try that again on your actual system?
>>> Markus
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
> Regards,
>    Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131022/e42313d2/attachment.html>
