[GRASS-dev] g.extension still broken in GRASS 7 on Mac
Vaclav Petras
wenzeslaus at gmail.com
Fri Oct 25 07:16:27 PDT 2013
On Fri, Oct 25, 2013 at 4:18 AM, Martin Landa <landa.martin at gmail.com>wrote:
> Hi,
> 2013/10/24 Glynn Clements <glynn at gclements.plus.com>:
> > You can override RUN_GISRC on the make command line if you want to use
> > a different $GISRC file.
> right, done in r58103.
> @Michael: please let us know if it works for you.
Why g.extension needs to write to a location? It is because it needs to
compile in PERMANENT/.tmp directory? Would be the system tmp directory a
better solution?
Vaclav
Martin
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131025/a922bdf2/attachment.html>
