Hi, 2013/10/24 Glynn Clements <glynn at gclements.plus.com>: > You can override RUN_GISRC on the make command line if you want to use > a different $GISRC file. right, done in r58103. @Michael: please let us know if it works for you. Martin -- Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
