[GRASS-dev] g.extension still broken in GRASS 7 on Mac
Fri Oct 25 09:20:19 PDT 2013
Michael Barton wrote:
> $GISBASE for the Mac is inside the GRASS-7.0.app. This is owned by
> the system, though I (as an admin) have read/write privileges.
> Normally this would be sufficient, but GRASS won't let anyone but
> the owner write to PERMANENT.
Clarification: GRASS won't let anyone but the owner select a mapset as
the current mapset, in the sense that G_gisinit() will generate a
fatal error if the owner of the current mapset isn't the owner of the
process.
It makes no difference whether the module would actually write to the
current mapset.
