[GRASS-dev] g.extension still broken in GRASS 7 on Mac - maybe OK
Michael Barton Michael.Barton at asu.edu
Fri Oct 25 13:54:41 PDT 2013
Wait,
My svn up didn't work first time around. Checking again.
Michael
______________________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
Tempe, AZ  85287-2402
USA
voice: 	480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax:          480-965-7671(SHESC), 480-727-0709 (CSDC)
www: 	http://csdc.asu.edu, http://shesc.asu.edu
		http://www.public.asu.edu/~cmbarton
On Oct 25, 2013, at 1:51 PM, Michael Barton <michael.barton at asu.edu>
 wrote:
> I just tried g.extension in GRASS 7 compiled an hour ago. Sorry but it is still broken in the same way. Do I need to add this to an existing bug report or file a new one?
> GRASS 7.0.svn (nc_spm_08):~ > g.extension extension=r.fuzzy
> Fetching <r.fuzzy> from GRASS-Addons SVN (be patient)...
> Compiling...
> main.c: In function 'main':
> main.c:152: warning: format not a string literal and no format arguments
> main.c:156: warning: format not a string literal and no format arguments
> ERROR: MAPSET PERMANENT - permission denied
> make[1]: *** [r.fuzzy.set.tmp.html] Error 1
> make[1]: *** [r.fuzzy.logic.tmp.html] Error 1
> main.c:151: warning: format not a string literal and no format arguments
> main.c:155: warning: format not a string literal and no format arguments
> main.c:157: warning: format not a string literal and no format arguments
> map_parser.c: In function 'parse_map_file':
> map_parser.c:92: warning: format not a string literal and no format arguments
> rule_parser.c: In function 'parse_rules':
> rule_parser.c:132: warning: format not a string literal and no format arguments
> make[1]: *** [r.fuzzy.system.tmp.html] Error 1
> Installing...
> make: *** No rule to make target `install'.  Stop.
> WARNING: Installation failed, sorry. Please check above error messages.
> Michael
> C. Michael Barton
> USA
> On Oct 25, 2013, at 7:31 AM, Michael Barton <Michael.Barton at asu.edu> wrote:
>> I'll try to recompile today if I can. Thanks.
>> Michael Barton
>> School of Human Evolution &Social Change
>> ...Sent from my iPad
>>> On Oct 25, 2013, at 1:18 AM, "Martin Landa" <landa.martin at gmail.com> wrote:
>>> Hi,
>>> 2013/10/24 Glynn Clements <glynn at gclements.plus.com>:
>>>> You can override RUN_GISRC on the make command line if you want to use
>>>> a different $GISRC file.
>>> right, done in r58103.
>>> @Michael: please let us know if it works for you.
>>> Martin
>>> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
