[GRASS-dev] [GRASS-user] G7-gui and G64 add-on problems on Xubuntu (installation from grass/ubuntugis ppa)
    Rashad M
    mohammedrashadkm at gmail.com
    Sat Oct 26 23:11:36 PDT 2013
Could try the addon package for grass6.4 from ubunutu ppa[1] which contains
most of them. There are builds for raring and saucy. But as you are using
12.04 LTS i had requested a build for Precise[2]. If would be helpful to
get it tested by others. Its been there for a while but I didnt hear any
issues regarding them maybe none used.
[1] https://code.launchpad.net/~rashadkm/+recipe/grass-addons-daily
[2]
https://code.launchpad.net/~grass/+archive/grass-stable/+recipebuild/568793
On Sun, Oct 27, 2013 at 2:38 AM, Hamish <hamish_b at yahoo.com> wrote:
> [sorry to break the thread but yahoo mail is more broken than usual today
> and won't let me reply to the other..]
> Cesar wrote:
> > To be able to install grass addons in 6.4.3 you need to install the
> > grass-dev package with sudo apt-get install grass-dev and then issue
> > the g.extension command
> Vaclav wrote:
> > Maybe, GRASS, namely g.extension, should identify the error (e.g.
> > check the include/Make directory) and report an error with a suggestion
> > (if on linux: "Check that you have package ..."). But this might be
> > very different for various distributions.
> Hi,
> the master debian packaging rules for 6.4 do add such a warning already,
> but
> only for the command line version of g.extension (which I was more
> comfortable patching at the time; patch for the python version welcome).
> http://anonscm.debian.org/gitweb/?p=pkg-grass/grass.git;a=blob_plain;f=debian/patches/check4dev;hb=HEAD
> so when you run it without the grass-dev package installed the first
> warning
> you get is to install the missing package. I don't know how often the
> Ubuntu
> custom PPA packagers sync with the updates to the debiangis packaging
> rules,
> but the warning has been in there for a year and a half or so already.
> IMO this is a packaging issue; any fix/warning due to packaging splits
> belongs
> with the packaging rules that did the splitting.
> > Probably also the package description and suggested/related packages
> > should provide some information.
> this is also already done,
> http://anonscm.debian.org/gitweb/?p=pkg-grass/grass.git;a=blob;f=debian/control;h=9f1191080f0ee9a5dcbcd9ebe4e62d9203ed5f13;hb=HEAD#l162
> grass-dev pkg description:
> "This package contains the header files for developing with GRASS.
> Install this package if you wish to develop software that manipulates
> GRASS data sets or install addons using the g.extension module."
> ISTR there was an issue if grass-dev was installed but the grass-doc
> package wasn't, but I think that's a bit of a corner case (->if grass-core
> was installed but the "grass" package wasn't). I think the problem had
> to do with the missing logo or css file, or perhaps the missing dir
> structure?
> I too get the emails about the broken 7.0 ppa build, according to the error
> message the latest issue seems to be a ubuntu dependency tangle in the
> new "trusty" version, best to give that some time to sort itself out:
> "State: Dependency wait"
> https://launchpadlibrarian.net/154922788/buildlog.txt.gz
> https://launchpadlibrarian.net/155002197/buildlog.txt.gz
> earlier I saw errors which the build log suggested were gcc bugs when
> builing
> ccmath, I assume an update for gcc would solve that.
> Finally, and not really related but while I remember, there's a problem
> building 6.4.3 on Itanium which I don't understand; build log:
> https://buildd.debian.org/status/fetch.php?pkg=grass&arch=ia64&ver=6.4.3-2&stamp=1380196645
> gcc -I/«PKGBUILDDIR»/dist.ia64-unknown-linux-gnu/include  -g -O2 -Wformat
> -Werror=format-security  -fPIE    -D_FORTIFY_SOURCE=2  -Wformat
> -Wformat-security -Werror=format-security  -Wno-error=format-security -Wall
> -O    -fPIC   -DPACKAGE=\""grasslibs"\"    -DPACKAGE=\""grasslibs"\"
> -I/«PKGBUILDDIR»/dist.ia64-unknown-linux-gnu/include -o
> OBJ.ia64-unknown-linux-gnu/window.o -c window.c
> gcc -shared -o /«PKGBUILDDIR»/dist.ia64-unknown-linux-gnu/lib/
> libgrass_display.6.4.3.so-L/«PKGBUILDDIR»/dist.ia64-unknown-linux-gnu/lib -Wl,--export-dynamic
> -Wl,-rpath-link,/«PKGBUILDDIR»/dist.ia64-unknown-linux-gnu/lib
> OBJ.ia64-unknown-linux-gnu/cnversions.o
> OBJ.ia64-unknown-linux-gnu/color_list.o OBJ.ia64-unknown-linux-gnu/draw.o
> OBJ.ia64-unknown-linux-gnu/draw2.o OBJ.ia64-unknown-linux-gnu/get_win.o
> OBJ.ia64-unknown-linux-gnu/ident_win.o OBJ.ia64-unknown-linux-gnu/list.o
> OBJ.ia64-unknown-linux-gnu/popup.o OBJ.ia64-unknown-linux-gnu/raster.o
> OBJ.ia64-unknown-linux-gnu/raster2.o OBJ.ia64-unknown-linux-gnu/setup.o
> OBJ.ia64-unknown-linux-gnu/symbol.o OBJ.ia64-unknown-linux-gnu/tran_colr.o
> OBJ.ia64-unknown-linux-gnu/window.o -lgrass_gis.6.4.3
> -lgrass_datetime.6.4.3 -lz     -lgrass_raster.6.4.3 -lgrass_pngdriver.6.4.3
> -lgrass_driver.6.4.3 -lgrass_gis.6.4.3 -lgrass_datetime.6.4.3 -lz
> -lfreetype    -lgrass_gis.6.4.3
>  -lgrass_datetime.6.4.3 -lz     -lpng  -lz  -lm  -lgrass_psdriver.6.4.3
> -lfreetype    -lgrass_gis.6.4.3 -lgrass_datetime.6.4.3 -lz
> /usr/bin/ld: OBJ.ia64-unknown-linux-gnu/raster2.o: @gprel relocation
> against dynamic symbol D__overlay_mode
> /usr/bin/ld: final link failed: Nonrepresentable section on output
> collect2: ld returned 1 exit status
> make[4]: *** [/«PKGBUILDDIR»/dist.ia64-unknown-linux-gnu/lib/
> libgrass_display.6.4.3.so] Error 1
> make[4]: Leaving directory `/«PKGBUILDDIR»/lib/display'
> thanks,
> Hamish
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Regards,
   Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131027/dd982753/attachment-0001.html>
