[GRASS-dev] [GRASS-user] G7-gui and G64 add-on problems on Xubuntu (installation from grass/ubuntugis ppa)
Jürgen E. Fischer jef at norbit.de
Tue Oct 29 05:34:13 PDT 2013
Hi Hamish,
On Tue, 29. Oct 2013 at 04:38:14 -0700, Hamish wrote:
> Tim wrote:
> > Yes, latest QGIS (daily) packaged based on nightly GRASS builds.
> > Th problem was that upstream was shipping the /debian files as
> > templates. These would need to be replaced by the build script.
> apparently the trick is to to edit the debian/changelog file,
> and on the first line replace UNRELEASED with the name of the
> distro version (template extension) you wish to use.
Or just follow in qgis' INSTALL 3.8[1] and add a changelog entry with something
like:
dch -l ~lucid --force-distribution --distribution lucid "lucid build"
Jürgen
[1] https://github.com/qgis/QGIS/blob/master/INSTALL#L304
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
QGIS PSC member (RM)                                   IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
