[GRASS-dev] [GRASS GIS] #1424: Profile tool always casts to integers (incl. csv output)
GRASS GIS trac at osgeo.org
Fri Sep 6 03:10:15 PDT 2013
 Reporter:  hamish                   |       Owner:  grass-dev@…
     Type:  defect                   |      Status:  new
 Priority:  major                    |   Milestone:  6.4.2
Component:  wxGUI                    |     Version:  svn-releasebranch64
 Keywords:  profile tool, precision  |    Platform:  All
      Cpu:  All                      |
Comment(by mlennert):
 A student of mine was bitten by this again, recently, so I looked into it.
 I'll attach a new patch which combines Hamish' original patch with the
 addition of using m.measure. This solves the issue of casts to integers
 (and no need for all the raster format checks Hamish suggested as the data
 actually '''is''' the original r.profile output with just nulls filtered
 out. And .15g seems appropriate for me as the output is then adapted to
 the type of data in input (i.e. integers are displayed as integers).
 I'm still a bit stuck on the use of the profile tool in lat-long
 locations. The use of m.measure was only one aspect. Antoher issue is on
 line 232ff where the resolution to be fed to r.profile is calculated.
 Using m.measure to determine the transect length gives a length in meters
 and thus the calculated resolution is in meters which then does not work
 for r.profile in a lat-long location.
 So, the patch is still unfinished work, but I'm very busy with other
 things these days, and do not have the time in the immediate future to
 look at this. Maybe someone else can pick up on what I did.
 In any case, it would be great to have the integer->float parts of the
 patch applied (and backported to 64release ?).
 Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/1424#comment:6>
