[GRASS-dev] [GRASS GIS] #1941: wxGUI fails with Japanese locale --> mixed Python installs on Windows
trac at osgeo.org
Wed Sep 11 13:35:29 PDT 2013
Reporter: venkat | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: wingrass | Platform: MSWindows 7
Cpu: x86-32 |
Comment(by hamish):
Replying to [comment:24 glynn]:
> Add-on packages don't normally care about the minor version, so
> a package built for 2.7 should work with 2.7.<anything>.
As seen in the pdf screenshot, the trouble comes with "import re", which I
think(??) is a built-in.
We recently saw the same trouble here with 'import re' -> no MAXREPEAT and
6.4.3 on a Windows 7 laptop, where there was a slightly older python
version of 2.7(.2?) installed to C:\Python, which I guessed came with a
separate OSGeo4W install(?). For us it was a new laptop not doing anything
else so we could uninstall the non-grass Python from the control panel and
then all was good.
Are we prepending to the PYTHONPATH instead of adding the grass paths to
the end of it? (hopefully the GRASS versions get picked up first then)
AFAIK env.bat & friends in the stand-alone installer now explicitly set
GRASS_PYTHON with with the full path to grass's python.exe.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1941#comment:26>
