[GRASS-dev] [GRASS GIS] #1778: Typing in g.region without parameters does not open a g.region window
trac at osgeo.org
Wed Sep 11 14:20:58 PDT 2013
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Default | Version: svn-trunk
Keywords: g.region, r.colors, r.mask | Platform: Linux
Cpu: x86-64 |
Comment(by hamish):
No, I don't think --ui should be added to the help page. It should only
needed in special circumstances (like debugging or having the main GUI
progmatically force open a dialog), much like --script and --interface-
description aren't interesting in the main help pages even though
possible.
I'm still highly confused about the need for any change since everything
seemed to be working very smoothly in GRASS 6. For example d.erase if
called alone would do its job without a GUI, you could add "color=black"
or whatever extra option on the command line if needed, or use --ui to get
a GUI module in the rare cases that you wanted one or add '--ui' to the
menus.xml file to force one if called from there.
Other modules in G6 that are special cases where no command line arguments
are needed (although possible) test argc or $# to decide how to act. Since
it's only a few of them special parser handling/support isn't needed, the
module programmer can make that decision on a one-off basis.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1778#comment:27>
