[GRASS-dev] Segmentation fault with r.to.vect
Martin Landa
landa.martin at gmail.com
Sun Sep 15 06:28:42 PDT 2013
2013/9/15 Pietro <peter.zamb at gmail.com>:
> r.to.vect input=basins_10k output=basins_10k type=area column=basin_num
> Segmentation fault (core dumped)
> Any hints? I'm the only one that have this problem?
> I did the distclean and recompile everything but the error is still there...
> I'm running 64bit Linux.
I cannot reproduce this problem (Debian GNU/Linux unstable 64bit).
Probably more detailed info (gdb output) will be needed to solve this
issue.
Cheers, Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
