[GRASS-dev] [GRASS GIS] #2080: wxGUI: changing properties of barscale or legend
trac at osgeo.org
Mon Sep 16 06:36:04 PDT 2013
Reporter: martinl | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: unspecified
Keywords: decorations, d.barscale, d.legend | Platform: All
Cpu: All |
Comment(by martinl):
Replying to [comment:3 annakrat]:
> > Another issue with the current method is that the north arrows (which
should probably be presented separate to the barscales in the GUI (perhaps
using wrapper scripts?) tend to get clipped off the edge of the
transparent background layer they are rendered on when using the default
placement. Otherwise I would have liked to swap the default GUI
legend/barscale placement top-bottom.
> wrapper script seems to be a good idea
currently you can add barscale or north arrow, but not both. Moreover
north arrow is not rendered well, better to say only right-side of the
north arrow is rendered (because default `x=0,95`).
Instead of making wrapper for adding north arrow (it will also require to
hide north arrow related options when adding barscale in wxGUI) what about
splitting this functionality into two separate modules, ie. `d.barscale`
and `d.northarrow`?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2080#comment:4>
