[GRASS-dev] [GRASS GIS] #2080: wxGUI: changing properties of barscale or legend
GRASS GIS trac at osgeo.org
Mon Sep 16 06:42:31 PDT 2013
 Reporter:  martinl                            |       Owner:  grass-dev@…
     Type:  enhancement                        |      Status:  new
 Priority:  normal                             |   Milestone:  7.0.0
Component:  wxGUI                              |     Version:  unspecified
 Keywords:  decorations, d.barscale, d.legend  |    Platform:  All
      Cpu:  All                                |
Comment(by annakrat):
 Replying to [comment:4 martinl]:
 > Replying to [comment:3 annakrat]:
 > > > Another issue with the current method is that the north arrows
 (which should probably be presented separate to the barscales in the GUI
 (perhaps using wrapper scripts?) tend to get clipped off the edge of the
 transparent background layer they are rendered on when using the default
 placement. Otherwise I would have liked to swap the default GUI
 legend/barscale placement top-bottom.
 > > wrapper script seems to be a good idea
 > currently you can add barscale or north arrow, but not both. Moreover
 north arrow is not rendered well, better to say only right-side of the
 north arrow is rendered (because default `x=0,95`).
 > Instead of making wrapper for adding north arrow (it will also require
 to hide north arrow related options when adding barscale in wxGUI) what
 about splitting this functionality into two separate modules, ie.
 `d.barscale` and `d.northarrow`?
 I completely agree. I just thought there is some reason that it's one
 module.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2080#comment:5>
