[GRASS-dev] [GRASS GIS] #2039: Startup Error
trac at osgeo.org
Mon Sep 16 17:35:43 PDT 2013
Reporter: akdeakin | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.4
Component: Startup | Version: 6.4.3 RCs
Keywords: wingrass, python | Platform: MSWindows 7
Cpu: x86-64 |
Comment(by annakrat):
Replying to [comment:17 annakrat]:
> The discussion continued in another ticket (#1941). It seems that Martin
solved the MAXREPEAT problem (do we need to test more?). It's not clear to
me if the original problem in description is also solved?
So there is another MAXREPEAT problem. When you run g.extension wrapper or
in python console:
grass.read_command('g.extension.py', flags='l')
you get nothing because of the MAXREPEAT error. But at least you can still
install extension through the the module dialog and command line.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2039#comment:18>
