[GRASS-dev] [GRASS GIS] #2039: Startup Error
GRASS GIS trac at osgeo.org
Mon Sep 16 17:36:31 PDT 2013
 Reporter:  akdeakin          |       Owner:  grass-dev@…
     Type:  defect            |      Status:  new
 Priority:  normal            |   Milestone:  6.4.4
Component:  Startup           |     Version:  6.4.3 RCs
 Keywords:  wingrass, python  |    Platform:  MSWindows 7
      Cpu:  x86-64            |
Comment(by annakrat):
 Replying to [comment:18 annakrat]:
 > Replying to [comment:17 annakrat]:
 > > The discussion continued in another ticket (#1941). It seems that
 Martin solved the MAXREPEAT problem (do we need to test more?). It's not
 clear to me if the original problem in description is also solved?
 > So there is another MAXREPEAT problem. When you run g.extension wrapper
 or in python console:
 > grass.read_command('g.extension.py', flags='l')
 > you get nothing because of the MAXREPEAT error. But at least you can
 still install extension through the the module dialog and command line.
 This applies to both standalone and OSGeo4W.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2039#comment:19>
