[GRASS-dev] [GRASS GIS] #2080: wxGUI: changing properties of barscale or legend
trac at osgeo.org
Wed Sep 18 10:33:57 PDT 2013
Reporter: martinl | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: decorations, d.barscale, d.legend, d.northarrow | Platform: All
Cpu: All |
Comment(by annakrat):
Replying to [comment:11 martinl]:
> Replying to [comment:10 annakrat]:
> > Please test r57738 if it is acceptable for you or you have any better
suggestions.
> much much more better! There is only one limitation - you cannot add
multiple barscales, legends, or northarrows, right?
Yes, but this limitation was there even before. The workaround is to add
the command layer which then behaves little differently (no moving
around). But I guess this is not the common requirement.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2080#comment:12>
