[GRASS-dev] [GRASS GIS] #2080: wxGUI: changing properties of barscale or legend
GRASS GIS trac at osgeo.org
Wed Sep 18 10:39:53 PDT 2013
 Reporter:  martinl                                          |       Owner:  grass-dev@…
     Type:  enhancement                                      |      Status:  new
 Priority:  normal                                           |   Milestone:  7.0.0
Component:  wxGUI                                            |     Version:  svn-trunk
 Keywords:  decorations, d.barscale, d.legend, d.northarrow  |    Platform:  All
      Cpu:  All                                              |
Comment(by martinl):
 Replying to [comment:12 annakrat]:
 > > much much more better! There is only one limitation - you cannot add
 multiple barscales, legends, or northarrows, right?
 > Yes, but this limitation was there even before. The workaround is to add
 the command layer which then behaves little differently (no moving
 around). But I guess this is not the common requirement.
 right, the correct sentence is "There is *still* one limitation".
Ticket URL: <https://trac.osgeo.org/grass/ticket/2080#comment:13>
