[GRASS-dev] grass compile error on launchpad
Štěpán Turek stepan.turek at seznam.cz
Fri Sep 27 00:38:43 PDT 2013
Hi Hamish thanks for quick fix,
Yesterday I tried to erase all compiler warning which gcc showed me. But I am not sure if I have correct setting of compiler to show me all warnings. Could you give me some advice with this?
Stepan
---------- Původtní zpráva ----------
Od: Hamish
Datum: 27. 9. 2013
Předmět: Re: [GRASS-dev] grass compile error on launchpad
Rashad:
> There are build failure on grass70 on GRASS PPA Launchpad.
>the part from error log:
> iscatt_core.c: In function 'compute_scatts_from_chunk_row':
iscatt_core.c:580:4: warning: statement with no effect [-Wunused-value]
iscatt_core.c:581:17: error: expected ';' before 'G_gettext'
> Is this only launchpad or anyone have problems because error message doesn't seems so
thanks,
Hamish
grass-dev mailing list
grass-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-dev
