[GRASS-dev] grass7 build error in ogsf
Massimo Di Stefano
massimodisasha at gmail.com
Sun Sep 29 12:05:18 PDT 2013
I'm tring to build grass7 with support for ffmpeg
I built ffmpeg from its git repository using this guide :
http://ffmpeg.org/trac/ffmpeg/wiki/UbuntuCompilationGuide
building grass i got error in OGSF, do you know how can i fix this ?
perhaps the ffmpeg version i'm using had an api change (is too recent)
thanks a lot for any help!
log :
epi at epinux:~/dev/grass7_trunk$ cd /home/epi/dev/grass7_trunk/lib/ogsf
epi at epinux:~/dev/grass7_trunk/lib/ogsf$ make gcc -g -O2 -fPIC
-I/home/epi/dev/grass7_trunk/dist.x86_64-unknown-linux-gnu/include
-I/usr/include/gdal -I/usr/include -DPACKAGE=\""grasslibs"\"
-I/usr/include/postgresql -I/usr/local/include/libavcodec
-I/usr/local/include/libavdevice -I/usr/local/include/libavfilter
-I/usr/local/include/libavformat -I/usr/local/include/libavutil
-I/usr/local/include/libswresample -I/usr/local/include/libswscale
-I/home/epi/dev/grass7_trunk/dist.x86_64-unknown-linux-gnu/include -o
OBJ.x86_64-unknown-linux-gnu/GK2.o -c GK2.c In file included from
/usr/include/x86_64-linux-gnu/sys/stat.h:106:0, from
/home/epi/dev/grass7_trunk/dist.x86_64-unknown-linux-gnu/include/grass/defs/gis.h:64,
from
/home/epi/dev/grass7_trunk/dist.x86_64-unknown-linux-gnu/include/grass/gis.h:577,
from GK2.c:21: /usr/include/x86_64-linux-gnu/bits/stat.h:91:21: error:
field 'st_atim' has incomplete type struct timespec st_atim; /* Time of
last access. */ ^ /usr/include/x86_64-linux-gnu/bits/stat.h:92:21:
error: field 'st_mtim' has incomplete type struct timespec st_mtim; /*
Time of last modification. */ ^
/usr/include/x86_64-linux-gnu/bits/stat.h:93:21: error: field 'st_ctim'
has incomplete type struct timespec st_ctim; /* Time of last status
change. */ ^ In file included from
/home/epi/dev/grass7_trunk/dist.x86_64-unknown-linux-gnu/include/grass/defs/gis.h:64:0,
from
from GK2.c:21: /usr/include/x86_64-linux-gnu/sys/stat.h:366:31: error:
array type has incomplete element type const struct timespec __times[2],
^ /usr/include/x86_64-linux-gnu/sys/stat.h:373:54: error: array type has
incomplete element type extern int futimens (int __fd, const struct
timespec __times[2]) __THROW; ^ make: ***
[OBJ.x86_64-unknown-linux-gnu/GK2.o] Error 1
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130929/409d3edb/attachment.html>
