[GRASS-dev] grass7 build error in ogsf
Markus Neteler
neteler at osgeo.org
Sun Sep 29 12:11:52 PDT 2013
On Sun, Sep 29, 2013 at 9:05 PM, Massimo Di Stefano
<massimodisasha at gmail.com> wrote:
> Hi,
> I'm tring to build grass7 with support for ffmpeg
> I built ffmpeg from its git repository using this guide :
> http://ffmpeg.org/trac/ffmpeg/wiki/UbuntuCompilationGuide
> building grass i got error in OGSF, do you know how can i fix this ?
> perhaps the ffmpeg version i'm using had an api change (is too recent)
> thanks a lot for any help!
> log :
> epi at epinux:~/dev/grass7_trunk$ cd /home/epi/dev/grass7_trunk/lib/ogsf
> epi at epinux:~/dev/grass7_trunk/lib/ogsf$ make gcc -g -O2 -fPIC
> -I/home/epi/dev/grass7_trunk/dist.x86_64-unknown-linux-gnu/include
> -I/usr/include/gdal -I/usr/include -DPACKAGE=\""grasslibs"\"
> -I/usr/include/postgresql -I/usr/local/include/libavcodec
> -I/usr/local/include/libavdevice -I/usr/local/include/libavfilter
> -I/usr/local/include/libavformat -I/usr/local/include/libavutil
> -I/usr/local/include/libswresample -I/usr/local/include/libswscale
> -I/home/epi/dev/grass7_trunk/dist.x86_64-unknown-linux-gnu/include -o
> OBJ.x86_64-unknown-linux-gnu/GK2.o -c GK2.c In file included from
> /usr/include/x86_64-linux-gnu/sys/stat.h:106:0, from
> /home/epi/dev/grass7_trunk/dist.x86_64-unknown-linux-gnu/include/grass/defs/gis.h:64,
> from
> /home/epi/dev/grass7_trunk/dist.x86_64-unknown-linux-gnu/include/grass/gis.h:577,
> from GK2.c:21: /usr/include/x86_64-linux-gnu/bits/stat.h:91:21: error: field
> ‘st_atim’ has incomplete type struct timespec st_atim;
Please see
http://trac.osgeo.org/grass/ticket/2017
especially
http://trac.osgeo.org/grass/ticket/2017#comment:12
Markus
