[GRASS-dev] grass7 build error in ogsf
Massimo Di Stefano
massimodisasha at gmail.com
Sun Sep 29 12:44:55 PDT 2013
Hi Markus,
i missed that trac issue.
I'll remove ffmpeg from the configure in order to have nviz working.
Thank you very much,
Massimo.
On 09/29/2013 03:11 PM, Markus Neteler wrote:
> On Sun, Sep 29, 2013 at 9:05 PM, Massimo Di Stefano
> <massimodisasha at gmail.com> wrote:
>> Hi,
>> I'm tring to build grass7 with support for ffmpeg
>> I built ffmpeg from its git repository using this guide :
>> http://ffmpeg.org/trac/ffmpeg/wiki/UbuntuCompilationGuide
>> building grass i got error in OGSF, do you know how can i fix this ?
>> perhaps the ffmpeg version i'm using had an api change (is too recent)
>> thanks a lot for any help!
>> log :
>> epi at epinux:~/dev/grass7_trunk$ cd /home/epi/dev/grass7_trunk/lib/ogsf
>> epi at epinux:~/dev/grass7_trunk/lib/ogsf$ make gcc -g -O2 -fPIC
>> -I/home/epi/dev/grass7_trunk/dist.x86_64-unknown-linux-gnu/include
>> -I/usr/include/gdal -I/usr/include -DPACKAGE=\""grasslibs"\"
>> -I/usr/include/postgresql -I/usr/local/include/libavcodec
>> -I/usr/local/include/libavdevice -I/usr/local/include/libavfilter
>> -I/usr/local/include/libavformat -I/usr/local/include/libavutil
>> -I/usr/local/include/libswresample -I/usr/local/include/libswscale
>> -I/home/epi/dev/grass7_trunk/dist.x86_64-unknown-linux-gnu/include -o
>> OBJ.x86_64-unknown-linux-gnu/GK2.o -c GK2.c In file included from
>> /usr/include/x86_64-linux-gnu/sys/stat.h:106:0, from
>> /home/epi/dev/grass7_trunk/dist.x86_64-unknown-linux-gnu/include/grass/defs/gis.h:64,
>> from
>> /home/epi/dev/grass7_trunk/dist.x86_64-unknown-linux-gnu/include/grass/gis.h:577,
>> from GK2.c:21: /usr/include/x86_64-linux-gnu/bits/stat.h:91:21: error: field
>> ‘st_atim’ has incomplete type struct timespec st_atim;
> Please see
> http://trac.osgeo.org/grass/ticket/2017
> especially
> http://trac.osgeo.org/grass/ticket/2017#comment:12
> Markus
