[GRASS-dev] [GRASS GIS] #2239: GRASS 7: v.to.rast -d produces empty raster when used on areas
GRASS GIS trac at osgeo.org
Tue Apr 1 03:38:43 PDT 2014
 Reporter:  sbl          |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  Vector       |     Version:  svn-trunk
 Keywords:  v.to.rast    |    Platform:  All
      Cpu:  Unspecified  |
 Converting areas from vector to raster (v.to.rast) with the -d flag (dense
 lines) results in an empty raster map.
 This is probably/likely because boundaries are not lines in a topolgical
 sense.
 It may be technically chalenging to desify also boundaries. Here one might
 probably have to distinguish shared boundaries (which can not be
 densified) and boundaries "owned" by a single area (which could be
 desified).[[BR]]
 In any case, it would be helpful to catch this behavior at least using a
 warning/error message and by adding information to the manual.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2239>
