[GRASS-dev] Grass to postgis topology export performance
Martin Landa landa.martin at gmail.com
Tue Apr 1 04:42:41 PDT 2014
2014-04-01 11:43 GMT+02:00 Rémi Cura <remi.cura at gmail.com>:
> Grass GIS is very fast to construct a topology over vectors (5 secs), and
> then surprisingly slow in exporting this model to Postgis topology (145
> sec).
> Is there a perticular reason for this? I tried to read the code, but
> couldn't get to the sql querries.
> Also, in a more prospective way, could Grass import from geometry (shapefile
> for example) then export to postgis topology be isolated (into an exe or a
> lib?).
could you post exact commands you run, or some sample data to play
with. Thanks, Martin
