[GRASS-dev] Color tables issues
Vaclav Petras
wenzeslaus at gmail.com
Thu Apr 3 19:29:56 PDT 2014
I just had three issues with color table.
1) First, I did not see anything when I showed the output of r.stats.zonal
in map display:
r.stats.zonal base=basin_10K cover=aspect method=sum output=test
d.rast test
But the values were ok, so I realized I that the preset color table is
wrong and I need to set my own.
2) It worked, however, the color table pictures were not in the r.colors
dialog. Note: I had freshly compiled trunk after make distclean (outside
GRASS session).
So, I went to raster/r.colors and run make inside GRASS session. I got the
color tables.
3) In the meantime, I noticed that color tables thumbnails are in docs
which is bad when some Linux distribution has the separate package for docs
(recently noted on mailing list).
I think that 3) is mentioned in the related ticket. Not sure if 2) relates
to recent changes in build GRASS session. 1) might be trivial to fix, not
checked.
Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140403/feae432f/attachment.html>
