[GRASS-dev] [GRASS-user] winGRASS 7 - R - integration - standalone/OSGeo4W - NEWS
Helmut Kudrnovsky
hellik at web.de
Sat Apr 5 15:29:09 PDT 2014
http://lists.osgeo.org/pipermail/grass-user/2014-April/070136.html
hi winGRASS-users,
at the Vienna Code Sprint GRASS GIS 7.0.0 beta 1 [1] went into the wild,
yeah ... :-)
so it was also time to update to update winGRASS 7 - R - integration (see
r59583 - r59590) with an update of the Windows batchfiles for use with R [2]
following R starting options should be now available with
winGRASS7-standalone :
o R cd - cd to R_ROOT, typically to C:\Program Files\R (0)
o R cmd - Run Rcmd.exe
o R dir - List contents of R_ROOT in chronological order showing R
versions (0)
o R gui - Run Rgui.exe
o R help - Help info (0)
o R path - Add R_TOOLS, R_MIKTEX & R_PATH to path for this cmd line
session (0)
o R Run R.exe (0)
o R script - Run Rscript.exe
o R show - Show R_ variable values used. R_PATH, etc. (0)
o R SetReg - Run RSetReg; see 2.17 in R FAQ for Windows (A)
o R tools - Add R_TOOLS and R_MIKTEX to path for this cmd line session
(0)
o R touch - Change date on R_HOME to now (0) (A)
also the wiki [3] is updated accordingly (text, but not yet the
screenshots).
at the moment this functionality is only available in winGRASS7-standalone.
if you want this nice integration also in OSGeo4W-winGRASS7 (and maybe also
other projects in OSGeo4W will benefit too), please express your opinion at
http://trac.osgeo.org/osgeo4w/ticket/413, it's yours ...
best regards
Helmut
[1] http://trac.osgeo.org/grass/wiki/Release/7.0.0beta-News
[2] https://code.google.com/p/batchfiles/
[3] http://grasswiki.osgeo.org/wiki/R_statistics#GRASS_7_Usage
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/GRASS-user-winGRASS-7-R-integration-standalone-OSGeo4W-NEWS-tp5133351.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
