[GRASS-dev] [GRASS GIS] #1214: r.li.edgedensity: segmentation fault
GRASS GIS trac at osgeo.org
Sun Apr 6 02:21:49 PDT 2014
 Reporter:  neteler           |       Owner:  grass-dev@…
     Type:  defect            |      Status:  new
 Priority:  normal            |   Milestone:  6.4.4
Component:  Raster            |     Version:  svn-releasebranch64
 Keywords:  r.li.edgedensity  |    Platform:  All
      Cpu:  x86-64            |
Comment(by mmetz):
 Replying to [comment:11 neteler]:
 > Open issues: the modules r.li.dominance, r.li.pielou, r.li.renyi,
 r.li.shannon,
 > r.li.simpson are not yet producing proper output. Since they appear to
 be similar
 > among each other, there might be the same issue to be fixed in all.
 > Help needed.
 I have cleaned up the backport to 6.4 a bit in r59598, then tested with
 the spearfish example described in the TODO, both moving window and whole
 region. The results are identical between G64 and G71. Can you test again
 and provide the example that produces incorrect results, if the results
 are still incorrect?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1214#comment:12>
