[GRASS-dev] [GRASS GIS] #2246: G7: r.shaded.relief result not added to layer tree
trac at osgeo.org
Mon Apr 7 15:12:18 PDT 2014
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-releasebranch70
Keywords: r.shaded.relief | Platform: Linux
Cpu: x86-64 |
Comment(by wenzeslaus):
Please specify if you've filled parameter `output` or not.
Because there is a strange thing in G7:r.shaded.relief that `output` is
not required and if you not specify it, a raster with the name
`<name_of_input>.shade` is created. And in this case there is no (easy,
currently implemented) way in GRASS how GUI can get know that something
was created (this is result of the separate processes design). In the
first case, GUI is guessing from the parameters.
The `output` should be always required, IMO, and the same applies for all
modules with the same behavior if there are any.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2246#comment:1>
